#79034 by Tim Mohr
Wed Nov 11, 2020 1:40 pm
Anyone getting occasional floating point overflow messages/crashes? I believe it stems from imported ACAD files but not consistent enough to be sure?
#79040 by Neil Blanchard
Wed Nov 11, 2020 4:29 pm
The only issue I have seen, is when deleting empty layers, in the Layer Manager. When do these crashes happen to you - are they related to something. or somewhat random?
You could try to Repair the file(s) - you close them, and then instead of Open, go the the Repair dialog.
#79044 by joshhuggins
Wed Nov 11, 2020 5:57 pm
I usually see overflow messages when I have random entity(s) way off in no-mans land. You can usually check by turning on all layers and doing a zoom extents and see if your drawing zooms WAY out. if so you can try deleting the offending entities, or if you can't find them copy and pasting the good contents of your drawing to a new file leaving behind the wonky stuff.
This would be where I would start but this may not be your issue. Could be an entity with some wacked out geometry that's math is running wild.
Users browsing this forum: No registered users and 81 guests
