#79262 by DBrennfoerder
Thu Jan 14, 2021 5:05 pm
What happened to the ability to do a 3d hide, with a choice of dashed or hidden blocked lines? When I ask for "Save Image" there are no options for dashed hidden, solid hidden or anything. It instantly gives me an iso-view with all surfaces transparent. All elements in my drawing are 3d polygons, or slabs.
#79263 by joshhuggins
Thu Jan 14, 2021 7:34 pm
Hi Dwight,
If you are accessing the HLR via the window menu at the top, right click to back out of the resultant HLR results to access the S8 Options menu to set those options or start off first accessing the tool via the Datacad menus from the 3D Edit menu so it doesn't jump to the HLR results first. Once you have your settings set, then you can use the top window menu to run your HLR's with the current settings.
#79264 by DBrennfoerder
Fri Jan 15, 2021 9:35 am
Thanks. I haven't used that one for years; needed it today; works great!
You guys rock!
Users browsing this forum: No registered users and 149 guests
