#79314 by DBrennfoerder
Mon Feb 01, 2021 11:34 am
V22.00.01.00 (PE)
Seem like 99% of the time if I try to delete a layer (not active layer) the file crashes without warning.
#79316 by joshhuggins
Mon Feb 01, 2021 2:55 pm
Hi Dwight,
Are you using the Layer Manager or the Datacad menus to delete the layer? There is an issue with the Layer Manager related to deleting empty layers that DCLLC is working on. If you are using the Datacad menus might be something in the drawing. Have you tried a repair or purging the file that has the issue?
#79318 by DBrennfoerder
Mon Feb 01, 2021 3:39 pm
Yes, the issue is when I'm using the Layer Manager. That's the way I've always done it, but now almost always crashes. I'll try the main menu instead.
#79331 by artmanvt2000
Thu Feb 04, 2021 11:44 am
Are you using the "Keep Layers Manager Open" option with the layers manager? If you turn it off, you should be able to delete layers using the layer manager. I have had the same problem with the layers manager.
Users browsing this forum: Google [Bot] and 111 guests
