#79499 by mijenix
Tue Mar 23, 2021 6:18 pm
I just upgraded to DataCAD 22 and have run into a problem when I draw a line by putting in a distance and angle. If I type in the distance and 0 it will draw the line at the correct angle, but if I type in the distance and an angle of 90 it will draw the line the correct distance but it draws it at an angle of 242. Other angles give similar problems. I am using Rel Polar input and my start angle is correct. Another strange thing is if I click to draw a line and move the mouse around to different angles it displays them properly. Anyone know what might be causing this.
Thank you
#79501 by dhs
Wed Mar 24, 2021 1:30 am
Sounds like your angle input setting may be radians. Check Settings/Angle Type and change to 'Normal' for degrees/minutes/seconds input if necessary.
Users browsing this forum: No registered users and 82 guests
