Line Feed = Text Height
Posted: Tue Apr 20, 2021 8:00 am
Does anyone know where to find the Line Feed = Text Height in the Text Menu? This shows up in the Paragraph Text Properties dialog box, but not in the Text Menu when setting the parameters for the inserted text. My problem with this setting, is that I have only been able to change it after I have applied the text. Is there a setting in the text menu that I am missing?
Thank you,
Thank you,
