forum.datacad.com • View topic - Enhancements to Batch Plotting
Page 3 of 3
Re: Enhancements to Batch Plotting
PostPosted: Mon Jul 12, 2021 4:24 am
by Mark Bell
PostPosted: Mon Jul 12, 2021 7:29 am
by Mark F. Madura
PostPosted: Mon Jul 12, 2021 6:04 pm
by Mark Bell
PostPosted: Tue Jul 13, 2021 12:54 pm
by The Canuck
I saw the option to collate.. hurray!!!!! It is becoming less and less that I print, but when I do it seems to be multiple sets and this is going to save a lot of time. Thank you Mark!!!!
PostPosted: Tue Jul 20, 2021 11:28 am
by Mark F. Madura
Question About Duplicate Names
The Batch Printing interface does not currently have any error checking for duplicate names. For example, the 'External' Batch Print Dialog allows you to load a SET file more than once, creating duplicate entries. If you're printing to PDF or PLT, files that are printed more than once will 'step' on previously saved files. I suppose if you're printing to a device, this would work, but why not just set Copies > 1?
Now that you'll be able to override the default naming convention; [Drawing Name-][Sheet ][Layout Name], there will be a greater opportunity to set the out filename to the same name in multiple files. If they are batch printed in the same session, the last layout printed will 'step' on the previous. Should this cause an error message?
It's possible to have duplicate GoTo View and MSP Sheet names. Should there be error handling for these conditions?
What about batch printing two drawings that have the same name, but are from different directories? The default output names would more likely be the same resulting in one of the files getting overwritten.
If you're diligent about names, you probably won't have any issues along these lines, but I'd like to get a better idea of what your expectation are.
Thank You,
MFM
PostPosted: Tue Jul 20, 2021 12:53 pm
While I might have similar drawing names, they all have the project number prefix, so I don't foresee having a duplicate name issue.
For those that might, couldn't you use a similar check that you have when inserting layers, a duplicate gets an (#) added to the end?
PostPosted: Wed Jul 21, 2021 1:52 pm
Will there be a way to drag order MSP between different drawings in the external batch plot dialog?
i.e.
Drawing 1 - Sheet A1.1
Drawing 2 - Sheet A1.2
Drawing 3 - Sheet A2.1
Drawing 2 - Sheet S1.1
PostPosted: Wed Jul 21, 2021 3:25 pm
by Mark F. Madura
PostPosted: Wed Jul 21, 2021 3:34 pm
by Mark F. Madura
PostPosted: Wed Jul 21, 2021 3:56 pm
PostPosted: Wed Jul 21, 2021 4:40 pm
by Mark F. Madura
PostPosted: Sun Oct 16, 2022 11:10 pm
by sam_bar
We have many files with many sheet sizes.
In the DATACAD software on WINDOWS, you can only print on paper sizes that are predefined in the plotter's driver.
If you want to print more than five sizes of paper (CUSTOM), you need to exit DATACAD and manually change the paper sizes in the plotter driver.
I don't understand how in this situation it is possible to print BATCH PLOTTING without manual intervention.
This could only be done as in DATACAD DOS,
Because the PLTPCUSTX and PLTPCUSTY variables in DCALDOS were still useful. They were modifiable from the DATACAD software itself, and saved in each DC5 file. It is these variables that determined the paper size in the QUICK LAYOUT, and not the sheet size lists that appear in the plotter's driver.
It would be great if the paper sizes were set from within the DATACAD software itself,
And these will be passed directly to WINDOWS DEVMODE.
PostPosted: Mon Oct 17, 2022 6:05 pm
by ORWoody
Adding external PDF files to batch printing would be an excellent feature for me. Especially so if it was order definable as can be set with GTVs. Inserting a PDF with the box checked would be wonderful. As Neil mentioned in his MSP desires, this feature/capability would save lots of inserting and rebuilding of drawing sets. Combined with the PDF merge... Wow!
PostPosted: Wed Oct 19, 2022 3:41 am
by Mark Bell
