Like Selection window not working correctly #80129 by Tim Mohr Wed Sep 22, 2021 8:57 pm Is anyone finding that the selection window is acting like a crossing selection when crossing function is not selected/switched on? Tim Username Tim Mohr Posts 139 Joined Tue Sep 15, 2009 12:03 pm Location Charlottesville, VA
Like Re: Selection window not working correctly #80142 by Neil Blanchard Fri Sep 24, 2021 9:32 am It sounds like you may have the option toggled on, that automatically toggles on Crossing when you draw it starting at the lower right, going to the upper left? If you draw it from the upper left, to the lower right, it is normal. Sincerely, Neil http://neilblanchard.blogspot.com/ Username Neil Blanchard Posts 8357 Joined Fri Feb 11, 2005 11:24 pm Location Maynard, MA, Eaarth Contact YIM
