Using Bluebeam Revu as PDF Plotter
PostPosted: Tue Oct 05, 2021 5:45 pm
by Twizzle
I normally use my A3 printer and print most plans in 1:200 on A3 for A1 plotting.
I have a project that requires a B1 sized plan and I have Bluebeam Revu which DataCad seems to recognize as a PDF plotter, as it appears in the plotter drop Down Menu.
When I select B1 size data cad just ignores whatever size and will only print in A1. When I select 1:100 and choose the Quick Layout command it only covers about 75% of the layout and regardless of my choosing say an A0 or B0 which is larger than B1 it does the same thing. So I have a project which I cannot effectively plot.
Any help is much appreciated.
Cheers
Re: Using Bluebeam Revu as PDF Plotter
PostPosted: Tue Oct 05, 2021 7:53 pm
by Joseph Baron
You could give PDF-XChange Lite a try, I think that's a free version and has a couple of B1 sizes.
PDF-XChange Lite B1.jpg (28.33 KiB) Viewed 2429 times
PostPosted: Tue Oct 05, 2021 8:57 pm
by Twizzle
I will give it a try, cheers
PostPosted: Tue Oct 05, 2021 9:18 pm
by Twizzle
Worked a treat, thanks for your help.
PostPosted: Wed Oct 06, 2021 8:13 am
by Joseph Baron
Twizzle wrote:Worked a treat, thanks for your help.
Great! Glad I could help out.
