Windows 11 - Right Click Not Working as Expected
Posted: Wed Dec 08, 2021 4:23 pm
I just upgraded to Windows 11 and ran into one issue with the 'Divide' function. When trying to select the first point the right-click does not grab the reference point. The right button on the mouse does not select the reference point. The right button works in Windows and all other applications (that I've tried so far) but not DataCAD. Any ideas on what might be causing the issue?
More info: When I click the right button on the mouse it changes the left menu panel (not sure about the proper name). For example, I click Alt-G to bring up the 'Geometry' options, Click 'Divide' which opens the 'Divide' options, select 'Divisions', then Select '2' for number of divisions. I go to select my first point and when I right-click the 'Divide' menu reverts back to the previous selection - the 'Geometry' menu.
Thank you,
David Haynes
Thank you,
David Haynes
