#80489 by DBrennfoerder
Wed Dec 15, 2021 10:04 am
Something corrupt.
I can no longer print this.
I updated DataCAD to latest. 22.01.12.02 (PE)
Actually, "print" does a print of a blank area; if I do "quick layout", the view is blank, not showing my work.
I sent the file to my draftsman; same on his. He can not print this either. He cannot layout and print other work either.
Help! We have hot deadlines.
(300.13 KiB) Downloaded 261 times
#80490 by joshhuggins
Wed Dec 15, 2021 11:47 am
Hi Dwight,
It is opening fine over here on my box on the same version. Maybe clean out your temp files folder? I did a New File Import, A Repair and A Purge on the file for good measure for ya and it looks to be working good here. Hope this helps!
(96.53 KiB) Downloaded 257 times
#80492 by MtnArch
Wed Dec 15, 2021 1:20 pm
I opened your file okay without doing any repair. Went to print it, and after resetting to one of my printers (a Brother 8.5x11) the QuickLayout did indeed show nothing, however after I zoomed WAY out I did see your entities. I reset the print scale to 1:400 and it showed up in the QL box.
Users browsing this forum: No registered users and 117 guests
