Re: Permanently Disable 'AND COPY' with the MOVE function???
Posted: Sat Apr 29, 2023 8:58 pm
Just ran across this thread.
I've been thinking about this for a while.
When i think of how to move or move and copy, I had the idea that you set your preference to "and copy or not". then when you use the command, there could be a key you press and hold down (like control) and it temporarily changes the setting while you're holding it down.
example: use move command set to not copy.
use your quick key to engage command.
Select your distance, layer, etc.
Then if you want to move and copy, hold down the key and select the items.
Then let up the key and your back to just move.
