New Dimension Visible Attribute Positioning
Wed Sep 14, 2022 4:51 pm
by Joseph Baron
I found this on page 90 of the What's New PDF. Can someone tell me what it's supposed to do if set to TRUE?
Re: New Dimension Visible Attribute Positioning
Wed Sep 14, 2022 5:21 pm
by Mark Bell
This is just a stab in the dark here so may not be correct, but a while back the ability to ctrl-right click over an existing dimension and then pick Reposition from the pop-up menu, was added as a new feature. This ini setting may relate to that feature?
Wed Sep 14, 2022 5:51 pm
by Joseph Baron
Relocate works the same whether that is T or F.
We have visible attributes on dimensions but they don't move when relocate is used so I'm curious to find out what it's supposed to do, the PDF just mentions the INI setting.
Thanks for the reply.
