forum.datacad.com • View topic - Crashing Files in DataCAD 22
PostPosted: Wed Nov 23, 2022 5:25 pm
by RHerbage
DataCAD 22 keeps crashing on our workstations and does not save the work done. Once you reboot the datacad program and re-open the effected file,
none of work has been saved and the swp file is not updated. Any ideas of a fix.
Re: Crashing Files in DataCAD 22
PostPosted: Sun Nov 27, 2022 2:47 pm
Hello Robert,
Hmmm, well its the crashing that isn't good - but the best/only way to get things saved is to use Control-S as often as you can.
Any thing(s) in particular being done before the crashes? Is it in some specific files, and not others? Or, is it happening when you are doing something?
What version of Windows are you using? If its Windows 11, there may be things that can be done - I don't use Win11; but there have been threads on this, I think?
PostPosted: Mon Nov 28, 2022 10:55 am
by Joseph Baron
PostPosted: Mon Nov 28, 2022 11:48 am
by RHerbage
We have 4 stations running DataCAD 22 with a save timer set at 5 minutes. I reset the session locations to be on each
computers c: drive in the DataCAD22 directory. All stations are networked to a central drive that the project files
are located on. Each station will freeze and require a reboot with loss of work up to the point of reboot. We have been
running DataCAD since 1987 and never experienced this before.
PostPosted: Tue Nov 29, 2022 11:49 pm
by Dave
What is the full path to where the auto save is going?
DaveR
PostPosted: Mon Feb 06, 2023 3:08 pm
by RHerbage
Dave,
The autosave, set at 5 minutes, is going to the E:\ Drive where the drawings are located which is on my computer station. It crashes when trying to save on exit and you get the following Error message "DataCAD (internal diagnostics) fault 8 Error from: 809". Session backups are not being added to the folder for that drawing file but the swp file is located in the temporary folder. It frustrating to spend a couple of hours on a drawing only to have it crash without the autosaves being done on the times as set.
PostPosted: Mon Feb 06, 2023 3:53 pm
My first instinct is this sounds like a hardware or drive / network resource permissions issue, but since we can't troubleshoot that too much from here, if you could open your dcadwin.ini file, copy the contents, come to the forum to reply and then click the 'Code display' </> icon which should inset a [code] [/code} and paste your dcadwin.ini file contents between these two code sections so we can take a look at your ini file and see if anything stands out.
Does the issue happen with a new blank AEC file?
PostPosted: Mon Feb 06, 2023 6:18 pm
by RHerbage
PostPosted: Wed Feb 08, 2023 12:37 pm
by Joseph Baron
It looks like your Sessions are set for D:\ instead of E:\
PATH_SESSIONS=D:\DataCAD\Session Backup\
