bitmaps auto rotating 90 deg from sel view
PostPosted: Tue Feb 28, 2023 3:12 pm
by jmsa
When I bring in a selected jpeg file it auto rotates 90deg and I cannot get it upright
Re: bitmaps auto rotating 90 deg from sel view
PostPosted: Tue Feb 28, 2023 3:50 pm
by Mark F. Madura
jmsa wrote:When I bring in a selected jpeg file it auto rotates 90deg and I cannot get it upright
DataCAD ignores the Orientation flag property that digital cameras and photo editors add to bitmaps. So, you'll have to rotate the image on disk before inserting it.
PostPosted: Tue Feb 28, 2023 6:43 pm
by MtnArch
A Cheap Trick (which I believe Clay came up with long ago) is to insert/reference the bitmap file into a blank AEC file, save it, and then xref THAT file into your main file. This allows you to rotate it to your hearts content. An extra step, but you don't have to play around in Affinity Photo / Photoshop / etc. with your photo, AND you can scale it to whatever size you need, too!
PostPosted: Wed Mar 01, 2023 9:28 am
I believe one can also make the image into a symbol and rotate the symbol.
