Batch printing forgets updated GTV layers xref MSP detail
PostPosted: Thu Jun 08, 2023 12:53 pm
by suttonarch
Batch printing forgets updated GTV layers on clipped xref MSP details.
The MSP sheet shows all the layers are properly on within the details. If I manually print it. It come out good. But when I batch print, some layers are turned off. I've tried updating the GTV and and have GTV on in the Xref. Thanks for any tips.
Re: Batch printing forgets updated GTV layers xref MSP detai
PostPosted: Sun Jun 11, 2023 8:04 pm
by Mark Bell
I think this may be an issue identified in the Beta testing that is yet to be resolved? I'm unsure if this is what you have been doing but the only suggestion you could try is to manually update each GTV when any changes have been made prior to changing a view or printing to ensure the GTV is the most current. Also check the path names to xrefs are current.
