toolbar preferences/size not responding
PostPosted: Tue Dec 26, 2023 5:11 pm
by Tim Mohr
Hi all -
Am using a fairly high resolution screen (3840x2160)...and I can't get DCAD23 to adjust toolbar pixel size (seems stuck on 16 - which would be fine if was 20 years younger :)
Re: toolbar preferences/size not responding
PostPosted: Wed Dec 27, 2023 9:45 am
Do you have the "Use External Toolbar Icons" turned on below the list of icon sizes?
PostPosted: Wed Dec 27, 2023 5:42 pm
by Tim Mohr
HI Roger -
that is switched off - also turned off the "lock toolbar" switch to see if that would help...perhaps this is something set in the ini file?
PostPosted: Thu Dec 28, 2023 9:34 am
Try turning on the "Use External Icons" and see if that helps.
I think you might need to restart DCAD for it to take effect.
PostPosted: Fri Dec 29, 2023 10:10 am
by Tim Mohr
Ah nope - that didn't work either. This was not an issue with 22 so am guessing there is a default setting at play here?
PostPosted: Thu Jan 04, 2024 4:44 pm
by Mark Bell
If you right mouse click on your Desktop to open the pop up menu, the scroll down to Display Settings then under Scale & Layout increase the percentage to what works for you. This should allow you to change the scale on the toolbar icons.
