Problem with Inc. Angles measure
Thu Feb 22, 2024 7:20 am
by Aaron Ben-Avraham
I am having a problem with measuring the Inc. angle between 2 lines (measures menu, S1) it always reports 0. If I go to dimensions and dimension angle, it reports the angle correctly. It is only from the measure menu I get the wrong answer. Is anyone else having this problem?
Aaron
Re: Problem with Inc. Angles measure
Thu Feb 22, 2024 7:36 am
by David Porter
I can confirm this. I tried this on a couple of files and different angles between 2 lines. I did restarts of DCAD and of the computer. About every 10th attempt, DCAD would show me the included angle measurement. The other attempts showed the angle to be 0-0 degrees.
Tue Mar 12, 2024 5:55 pm
by Mark F. Madura
Sorry about that. If the lines share an endpoint, the calculation will return an incorrect result of zero. Corrected for the next builds of DataCAD 22 and 23.
Thu Mar 14, 2024 4:18 pm
Thanks for the update Mark!
