Vertex visibilty /size
Mon Apr 15, 2024 6:47 am
by Tim Mohr
Can't believe I am asking this after using DCAD for the last 15years or so, but is there a way to adjust vertex visibility/size for polylines? It's one of those incredibly annoying little quirks that drives me crazy when I zoom out from a complex polyline and all I can see is sea of dots with circles...particularly problematic when importing from other programs that have been drawn in polylines...and exploding to line just quadruples the number of entities...setting in ini perhaps?
Re: Vertex visibilty /size
Mon Apr 15, 2024 8:10 am
by Mark F. Madura
You can toggle off Draw Marks in 3D Edit ---> Settings, or you can try setting Auto Adjust Marker Size Percentage in the [Display] section of DCADWIN.ini to a value less than 100 like 50 (50%). I usually just toggle them off since they add 4 lines per node to the display list.
Sun May 05, 2024 2:32 pm
by Tim Mohr
Hi Mark -
I am not finding that line in the ini file...?
Sun May 05, 2024 2:56 pm
by Mark F. Madura
Tim Mohr wrote:I am not finding that line in the ini file...?
If it's not there, you can add it.
Auto Adjust Marker Size Percentage=50
Add the key to the [Display] section.
Sun May 05, 2024 11:34 pm
Hey Mark, if we set this to 0% would it act as if they are turned off from a performance stand point or would they still be display list processed, but just not displayed ?
