Hi all.
Does anyone know of an alternative to Adaptec's Easy-CD Creator 3.5c, for an XP machine ... primarily for creating jewel case inserts? I had been using that version or earlier for many years, which does EXACTLY what I want.
In reality, I don't even care about the cd burning. The software that came with this machine (at work) does that ok. What I am looking for is a way to EASILY create the jewel case inserts like I can at home with ECDC 3.5c on my W98SE machine.
I have downloaded and tested a bunch of cd and jewel case label makers that all suck for what I want. The big thing that none of them seem to do is a data snapshot, with the folders expanded as I want to display them, in order to get the index info I want, without having to type it all in.
If all else fails, I can do screen snapshots (by area) in Windows Explorer of what I want, save the image, then add that to a cad file I've set up in order to create the insert ... but that is WAY more work than what I'm used to doing for getting the same results.
Steve
Steven R. Baldwin
SRB Ventures
Joplin, Missouri - USA
Steven R. Baldwin
SRB Ventures
