Post off topic threads here.
#64682 by capri-express
Tue Aug 12, 2014 6:48 pm
Hello Group,
I am looking for a 3D model of a Chevy Tahoe. I bought a 3D DXF and DWG file, but I cannot view the entire file. I am currently using DataCAD 10.02.01. I asked the model people to please send me an AutoCAD 14 or 2000 DXF and DWG. They did, but I still cannot view the entire model. I will tell you that the model I downloaded is the entire engine, transmission, exhaust and interior. I also see that when I downloaded it, everything is on one layer. It is a 415,548 kb DXF File. All I really need is just the exterior of the vehicle. All that I can see now is the rubber strip that goes on top of the step bars on the outside of the vehicle.
Thanks for your help.
Al
user since DataCAD 5 DOS
#64684 by capri-express
Tue Aug 12, 2014 7:19 pm
I guess that I should clarify that I am trying to use a 3D model in o2c. This way I can set it rotating slowly and use Snagit to generate a short video. I am trying to make a video for a company that is making an accessory that attaches to the outside of the Chevy Tahoe. I see that there is a simple SUV in the DataCAD Site Template that I can probably edit (a lot). I was hoping to start with a better 3D model. This not what I normally use DataCAD for, but it is something I am trying to do. I did buy a 3D model from Humster 3D, but neither the DXF nor the DWG file will load in DataCAD. I did request that they send the files to me in AutoCAD 14 and AutoCAD 2000 format.
#64697 by Robert Scott
Sat Aug 16, 2014 2:03 am
If you have Sketchup you can try to import the DWG/DXF into Sketchup. Clean up the model and throw away everything you don't need to make the model lighter. Then export into DataCAD.
#64698 by Robert Scott
Sat Aug 16, 2014 2:45 am
Here's a 2013 Tahoe I converted from Sketchup. You'll have to clean it up a bit and map your colors.
https://www.dropbox.com/sh/3in9ymflxjrc ... UKyQsUMLxa
#64714 by capri-express
Tue Aug 19, 2014 2:07 pm
Hello Neil,
I clicked on his dropbox and there is a 2013 Chevy Tahoe there, but it has a .aec file extension. I don't know if this is the newer file extension, but DataCAD 10 is using a .dc5 file extension. Hopefully I will be getting an upgrade soon and will be able to avoid these hassles.
Thanks for your assistance.
Al
#64716 by capri-express
Tue Aug 19, 2014 10:06 pm
Hello Robert,
Thank you!
I just downloaded and imported it into DataCAD10. I can see that I need to move a lot of parts up in Z level, but most of it is there. I don't see the hood or front fenders. I am attaching a screen capture of what I got. You can see that most of it is there, but the steering wheel is below the vehicle, the gauges are behind the vehicle and a lot of it is at a zero height.
Thank you again.
Al
2013 Tahoe.JPG (194.32 KiB) Viewed 20095 times
#64717 by Robert Scott
Tue Aug 19, 2014 10:53 pm
Hmmm...somethings not right.
Here is what I get when I open the AEC file.
Image 2.JPG (132.27 KiB) Viewed 20085 times
Image 1.JPG (58.02 KiB) Viewed 20085 times
#64719 by joshhuggins
Wed Aug 20, 2014 2:17 am
Could be due to the single precision floating point in Datacad v10 vs. double in v11?
#64731 by joshhuggins
Wed Aug 20, 2014 5:24 pm
Maybe try 3DS?
#64728 by capri-express
Wed Aug 20, 2014 10:34 pm
Is it possible to save this 3D model in a .dc5 extension instead of a .dwg? Or is there another way to save this so I can open/import it into DataCAD 10?
Again I do appreciate your help.
Al
