In the past, I was able to print my business cards using the heavy chisel font, but at the moment I cannot. The SHX font is in DataCAD's font folder, but I'm thinking that the Avery Dennison program only can use the fonts in the Windows font folder.
How do I get a heavy chisel font available to Windows?
I assume you are talking about ARCWY2HC, I thought DCAD installed it as a true type font. I have the TTF file in my windows/fonts directory. I can email it to you if you would like.
Yes, that is the font -- and I thought it got installed as part of the DataCAD installation as well. But for whatever reason, it is not on my WinXP. I would appreciate it if you could send it to me; thanks.
