I occasionally get pdf prints of cad files from other sources. When I try to print them on my HPLJ 5000, it prints only a small portion of the file at the left edge. It has been suggested that I need to add more memory to the printer - it currently has 24mb. However, the pdf size is about the same if not smaller than my Datacad generated pdf's, which print fine and I can watch it spool up and the file size is usually around 1.8mb going to the printer. Does anyone have any idea what is causing the printer to cut off some pdf's and not the others?
Dick
DataCAD user since version 2
