My Uncle who spent years at International Paper as a plant designer (and was responsible for first getting me interested in drafting) sent me this today ( I especially like # 26 - NEVER EVER did use the silly darn thing
You know you are an old Draftsperson when...
1. You know how to control line weights by rolling your pencil.
2. You know that a French curve isn't a grade change on a language exam.
3. You remember when blueprints were blue.
4. You've erased sepias with chemicals.
5. You know a scumbag isn't just a derogatory comment about someone.
6. You know what drafting dots are and how to use them.
7. You know that a Leroy Lettering Set is not a ACAD font.
8. You've had a roll of toilet paper on your drafting board.
9. You remember when templates were plastic and not a type of electronic
file.
10. You know what sandpaper on a stick is for.
11. You know that a compass draws circles not to find the North
pole.
12. You remember the head rush from the smell of ammonia.
13. You own a roll of masking tape so dried out, it will never be
tape again.
14. You've played with a drafting dot ball.
15. You know what the phrase "asses and elbows" means.
16. You've done cut and paste with scissors and sticky back.
17. You've etched your initials into your tools.
18. You have had a brush tied to your drafting board.
19. You've come home with black sleeves.
20. You've made hooks out of paper clips to attach to your lamp.
21. You know an eraser shield isn't a Norton program.
22. You've used "fixative" spray.
23. You've had a middle-finger callous harder than bone.
24. The words "sepia changes" still gives you a headache.
25. You've used Pounce.
26. Having an Ames lettering guide and never using it.
And finally...
1. You have a permanent spine curvature from bending over your table
file.
pole.
tape again.
And finally...
