Hey guys I have a situation where I need to mark a slanted post parallel to the ground plane of it's current location for a cut line that will be cut later once dug up. I was trying to think of a way or device that would allow me to set the height of the cut line off the adjacent ground plane and trace around the post. My other idea is a laser level and manually marking the post, but I am not sure I can get that to work since the cut line is just a little more than an inch off the ground and I think my laser level would be too high, I haven't check it yet. I was thinking of some sort of wheeled device that might hold a marking pen. The red plane and grey plane are parallel. Any ideas?
Plane Cut.PNG (8.4 KiB) Viewed 9735 times
Thanks! - Josh
