Looking for "standard" drawings to purchase
Posted: Mon Jan 02, 2023 10:54 am
Happy New Year All!
I have been using DCAD on and off since the 80s. I'm gliding toward retirement and have never really used DCAD to its fullest potential - since I started with a T square and triangles, I pretty much have used it more or less of an "electronic pencil". Because of that I tend to redraw a lot of things that don't need redrawing. To that end I am looking for some standard drawings that I typically have not included in sets, but probably should to save time.
All that to ask if anyone knows of a source where I could purchase (in DCAD format - I use DCAD 22) any standard drawings that are typically used in drawings sets, such as sheets showing typical ADA mounting diagrams/dimensions, abbreviation and legend sheets, typical detail sheets, etc. etc. I have old CDs of Cheap Trick Ware volumes 1 & 2 and have gleaned some stuff from that, but still could use a lot more. (I really miss Evan Shu BTW).
Also if anyone knows of a way to install some of the macros, etc. from the Cheap Tricks Ware CD onto my DCAD 22 program, I would appreciate it - probably a lost cause?
Thanks in advance for any help you can offer!
