Page 2 of 2
Wed Mar 02, 2005 12:09 pm
by Daniel Kaczor
Dick Eades wrote:Oh, no!! Now that it's working it's copying in the quoted posts after I edited the original.
Sorry about that!
No, not really, I was trying to post the correct syntax and accidentally linked the image. Actually, it was my bad.
Wed Mar 02, 2005 12:32 pm
Hello Dick:
Here's how I did the smaller images as links to the large images:
[url=location of LARGE image][img]location%20of%20smaller%20image[/img][/url]
Wed Mar 02, 2005 12:36 pm
by Dick Eades
Thanks, Neil. I'll correct that later when I have time. In the meantime, bear with me.
Fri Mar 25, 2005 4:38 pm
by Steve Baldwin
Hi all.
I've gotta use black! White works fine in other programs, but for some reason, when I'm in cad, it has to be black.
Background color
Sat Mar 26, 2005 12:57 am
by DBrennfoerder
I used black or a very dark green or blue, unless using the projector at a client meeting. At meetings I usually switch to white to make the lines show up better. Sometimes I need to do a "change/color/all" window to make light cyan, yellow, and others show up better in a temp/copy file of the cad file.
Sat Mar 26, 2005 11:42 am
by Dick Eades
No need to do that, just load a different rgb file. Prepare one that looks good on a white background and save it for the presentations.
RE: rgb file change
Sat Mar 26, 2005 8:34 pm
by DBrennfoerder
Thanks Dick. I knew there should be some easy way around the problem, just hadn't taken time to think it through.
Sun Mar 27, 2005 11:44 am
by Dick Eades
I converted from a black background to white and had to be able to use a huge legacy of symbols that would have been difficult to redefine just in order to change their colors, so the easiest solution was to develop a custom rgb file that allowed those colors to remain assigned to their respective plotter roles and yet look appropriate on a white background. My solution was posted earlier here.
Tue Mar 29, 2005 10:56 pm
by Daniel Kaczor
Dick Eades wrote:No need to do that, just load a different rgb file. Prepare one that looks good on a white background and save it for the presentations.
How do you do that? My Tools>ColorPalettes dialogue box only has SaveAs, Edit, OK, and Cancel buttons, no Load button. Page 174 of the DataCAD 11 manual shows a Load button, but, mine looks like the one on Page 30 of the What's new.. manual.
Is there an datacadwin.ini entry I'm missing?
I would like to change palettes for a presentation on Thursday, I guess I can always change the ini.
Loading .rgb Files
Wed Mar 30, 2005 1:11 am
by Steve Baldwin
Hi Daniel.
It took a second for me to find that too. Actually, there isn't a load button. Just use the drop-down arrow to show the list of .rgb files, then select the one you want. ...You may need to refresh your screen.
Re: Loading .rgb Files
Wed Mar 30, 2005 8:19 am
by Daniel Kaczor
Steve Baldwin wrote:Hi Daniel.
Doh!! Never occurred to me. Thanks for the help.
Thu Mar 31, 2005 5:30 pm
by REX PEET
I use 0 0 255 Blue. I find it much more relaxing for the eyes than either black or white
Mon Apr 25, 2005 5:21 pm
by Ted B
I use a real dark blue, like the old white line-on-blue blueprints. It's just "blue"-enough to see sensed as a plane...rather than staring into a black endless Abyss. And it's neutral enough not to throw any of the std. colors off.
On my monitor I don't use Blue or Dark Gray anyway, and I rarely use Magenta.
Mon Apr 25, 2005 5:55 pm
by Miguel Palaoro
Dick Eades wrote:...I notice that Neil has a smaller picture with a link to a larger one. How do you do that?
Hello Dick,
Try to use PNG format. It is browser friendly. Which means it will fit the window size and allow the swap between little and bigger image.
Additionaly PNG is a great solution because it doesn't loose quality on the image as JPG does.
Miguel
