There used to be a code requiring the garage floor to be a step down from the main living area floor in an attached garage to act as a fume barrier. I say used to because an architect I am dealing with says it is no longer required. Does anyone know where this was specified in the code or can anyone confirm that this is no longer required?
I am working on an accessible plan and the architect is figuring the garage floor to be flush with the first floor slab. It will then slope to a floor drain in the middle of the garage. This would eliminate the need for a ramp but I just want to make sure.
I have calls into a few building officials but have not gotten the call back yet and thought I would post this here.
Thanks in advance for any replies.
AJ Blasio (aka Tony)
Windows 10
Intel CORE i5
8GB Ram
Windows 10
Intel CORE i5
8GB Ram
