Greetings Don,
I'm posting your question here on the Forum, because it has been a long time since I have used a MS mouse, and hopefully someone who knows can help you out. Also, the next time someone has a similar question, the answer will be here for them to find.
When I last used an MS mouse, there was a checkbox for "Office 97 Compatible Scrolling" in the control panel, and when it is checked, the scroll wheel does object snaps like it should. But, recently, I was told that this did not help -- or maybe that setting is no longer in the mouse CP?
[Edit: It should be "compatible" with anything in Windows, in that it should be able to made to work.]
I cannot get the wheel to engage a line or anything else when I use it. Just bought the unit for an HP portable. Is it compatible with Datacad 11? If so can you help me figure out.
Don.
