Are files backward compatible to v.10 from v.11? I have an oppty to work with a v.11 user, I'm running v.10. Looking for a way to make it work without an upgrade if possible.
thanks -
thanks -
.CAD user since v.3:.
yoga wrote:Are files backward compatible to v.10 from v.11? I have an oppty to work with a v.11 user, I'm running v.10. Looking for a way to make it work without an upgrade if possible.
thanks -
can you install 11 and keep 10 in tact for this reason and run both versions, until everyone upgrades to 11
joshhuggins wrote:can you install 11 and keep 10 in tact for this reason and run both versions, until everyone upgrades to 11
Yup, just make sure the default install of 11 goes to a different location (which it should be, because it now defaults to your program files folder). The Dcadwin.ini files for 11 are now stored in the datacad folder now, so the install of 10 will still use the ini installed in the Windows folder.
Users browsing this forum: No registered users and 64 guests
