I have just started trying to use fills for elevation studies. I notice that the fills sometime "bleed" over the containing lines. This bleeding can appear both on screen and on printouts - although the location and quality are not consistent from screen to paper.
I use fills in every drawing I create and never notice any bleeding. If it were occuring on the paper alone then I would say that the paper was probably just a cheap bond or something but if its bleeding over on the screen then that truely is weird. I am sure someone here might have some idea as to whats going on but I have not experienced that yet.
Where is the "overshoots" setting mentioned? I have trouble with the contiguous search. It keeps going and going and going sometimes like there's a hole in the area I'm filling. I clean everything up and still the same. Is there a way to avoid that?
