#12846 by Neil Blanchard
Thu Jul 20, 2006 7:30 am
Hello Jeff,
Each of the macros can only be run in one file at a time -- since you are using the same program/software, they can only be run once. I have not tried it, but if you had two copies of the macros you need to use a lot (in different folders) then you might be able to make this work?
#12849 by Paul Nida
Thu Jul 20, 2006 8:17 am
You can just copy the macro in the same folder and give it a different name, like DCSPRINT1 and DCSPRINT2. That should work with out any problem.
#12867 by joshhuggins
Sun Jul 23, 2006 7:02 pm
Good tip Paul :!:
Users browsing this forum: Google [Bot] and 31 guests
