#13324 by solid
Fri Aug 18, 2006 3:18 pm
Hi All,
I am a AutoCAD developer with little knowledge of DataCAD. I need to export this type of drawing to dxf/dwg. Only problem is the text does not come through in the dxf/dwg, just the plines.
Could someome tell me if this is possible. If not directly I would obviously pay someones fee to help me with a solution.
I didn't know how to attach a drawing, so I posted it here.
http://www.richcad.com/DataCAD/
I appreciate all ideas.
Thank you,
Paul
#13326 by solid
Fri Aug 18, 2006 3:25 pm
solid wrote:Hi All,
Thank you,
Paul
PS, If anyone is skeptical of the file from an unknown poster, please see
any of the AutoCAD groups, you'll find I'm know well there.
http://discussion.autodesk.com/search.j ... umlist%7C8
Thank again for your time,
Paul
#13327 by joshhuggins
Fri Aug 18, 2006 3:30 pm
The text in that Datacad file is actually polylines, not text. Have to check with whoever gave you that file and see how and why they created that text using a polyline. This was probably not originally created in Datacad. Are you trying to create a AEC viewer/converter?
#13328 by Miguel Palaoro
Fri Aug 18, 2006 3:49 pm
Hello Paul and Josh,
May be this drawing was created in an AutoCAD application, with text attributes, and when exported it came attached as a single polyline.
I've tested here and could explode it to 3D lines, and the text itself converts into a bunch of 3d lines, but keeps viewed in the screen.
Differently, as a polyline, when converted back to 2d lines the text is vanished.
If the original creator 'un'attaches the text from the rectangle it perhaps could be translated correctly. I hope.
Miguel
#13329 by solid
Fri Aug 18, 2006 3:50 pm
joshhuggins wrote:The text in that Datacad file is actually polylines, not text. Have to check with whoever gave you that file and see how and why they created that text using a polyline. This was probably not originally created in Datacad. Are you trying to create a AEC viewer/converter?
The data is created by a program running in DataCAD. Funny the plines
that make up the text do not come through in dxf/dwg. Just the rectangular plines. Looks like I'm sol, it was written many years ago (dc5) and I don't have contact with the Author.
Thanks for your help.
Paul
#13330 by solid
Fri Aug 18, 2006 3:55 pm
Miguel Palaoro wrote:Hello Paul and Josh,
Miguel
Thanks, I was wondering why I couldn't explode the data somehow. This is ugly. There are hundreds of these per drawing and thousands of drawings. OUCH.
Cheers,
Paul
#13332 by joshhuggins
Fri Aug 18, 2006 4:20 pm
Do you know the name of the program? (probably a macro) Someone might have a work around. Do you have the original DC5 file?
#13333 by solid
Fri Aug 18, 2006 4:36 pm
joshhuggins wrote:Do you know the name of the program? (probably a macro) Someone might have a work around. Do you have the original DC5 file?
It was a custom program. I don't even know what language it's in. I will get a copy of it on Monday morning. Just tried their office and everyone is gone.
Thank you Gentlemen!
Paul
#13340 by Miguel Palaoro
Sat Aug 19, 2006 2:54 pm
I'd like to put my eyes on the original .DC5 too, if available, of course.
Miguel
#13385 by solid
Tue Aug 22, 2006 3:33 pm
Miguel Palaoro wrote:I'd like to put my eyes on the original .DC5 too, if available, of course.
Miguel
Gentlemen, Thank you all for your time. I was denied permission to
post an actual drawing.
I will instead dig into the code, myself and post necessary portions.
Don't even know were the code is, as someone here mentioned probably
in a macro, inbeded in the drawing?
As soon as I find it, I will post the necessary chunks to see if you can help. Were macros the only way to go with dc5, what language.
Again Thank you,
Paul
