Can one convert *sm6 symbols to be used in DataCAD 11 without having DataCAD Plus?
Regards, Eugene Barnard
[SymbolBrowser]
ConvSM3ToDSF=TRUE
joshhuggins wrote:Yeah. An easy way to do it is to use this is set Datacad's ini file to match:Code: Select allThen in Datacad, use the symbol browser to browse each folder where you have the sm3 files. Datacad will convert them to the dsf format and you'll be all set. Don't forget to delete the old sm3 files once your done.[SymbolBrowser]
ConvSM3ToDSF=TRUE
Users browsing this forum: Google [Bot] and 82 guests
