Hi,
just want to know whether anybody has experienced the same problem with printing to PDF files. I have a drawing setup to print using MSPs, to which I may add I find very easy to use and is one of datacad best points.
I have two sheets set up and when I print to a PDF file datacad drops the sheet number off from the named file. Therefore the second PDF file prints over the first PDF file because there is no distinction between either file. I have experienced this on a number of occasions and was wanting to know whether anyone else had experienced this. Does anyone know why this should happen and how I can prevent it from happening again.
I have to print the file to a PDF file separately and manually change the name so that the second file doesn't print over the first one.
Any help would be appreciated.
Many thanks.
Bruce
Many thanks.
Bruce
