Can hot key be set up, i for Indentify and set? Like I is for Indendify.
If you are using the full version of DataCAD (as opposed to LT), then sure; Alt-I (ID/Set All) is the granddaddy of all shortcuts!
Code: Select all
I^·^È^;^S1^$^S8^S0¸^É
Copy and Paste this into the DataCAD/Support Files/DcadWin.MCR file at the approriate location, and that should do it! (If you are using v10 or earlier, it is in the SUP folder.) Enjoy.
