Do you mean fill with either hatching or solid fill without having to pick the boundary? If so then yes, you can use the Contour Search, which typically fills each contiguous area of wall in one click. This works great if you have clean drafting with all the corners cleaned, no butted lines or unexploded symbols or superimposed lines.
