#22465 by David A. Giesselman
Tue Apr 10, 2007 1:49 pm
From Windoze:
  • Start
  • Run
  • Enter regedit when prompted for what to open/run
  • Your registry will be opened in a familiar Explorer style dialog
  • Expand HKEY_LOCAL_MACHINE
  • Expand Software
  • Find the branch named DATACAD LLC and highlight (select) it
  • Select Registry (or File) from the menu bar
  • Select Export Registry File...
  • In the file save dialog under Export range, choose Selected branch
  • Name and save the file
    NOTE: I would save the file to your DataCAD folder to be backed up along with everything else. Then, when you restore your DataCAD directory, all you need do is double click on the registry file to import it.
As always, use extreme care when exploring/editing your registry.
#22469 by peter korzaan
Tue Apr 10, 2007 2:13 pm
ok ..everything is fine until I get to DATACAD LLC, I do not see any REGISTRY in there.
There is:
under name (Default)
type REG_SZ data
data (value not set)
then a sub folder DATACAD r (with a circle around it)
and a sub folder to that ... 11 with several info name, serial # ect.
Note this... my dcad 11 is in .. c:\DataCAD ..not in programs..
I take it once I do find it, highlight it, go to file, Export?
#22471 by David A. Giesselman
Tue Apr 10, 2007 2:18 pm
Yes, depending upon the flavor of Windows you are running, Export Registry File... is located under either File or Registry on the menu bar. Sorry for the confusion, but I didn't write Windows. :wink:
#22473 by peter korzaan
Tue Apr 10, 2007 2:59 pm
Ok.. running XP, should have stated that..
so it makes no difference where I have Dcad, and even though it doesn't say registry, I have found the mother load... ?? labeled default, and now just copy it??
excuse me for being so dense, but as noted..
"As always, use extreme care when exploring/editing your registry."
yikes... ;-)
#22478 by joshhuggins
Tue Apr 10, 2007 4:02 pm
David A. Giesselman wrote: Sorry for the confusion, but I didn't write Windows. :wink:
That would be a pretty cool OS I'd bet. DG Smart Windows 2007. Now with Smart Doors & Walls too :!:
See this a good example of a nonsense post.
#22479 by MtnArch
Tue Apr 10, 2007 4:14 pm
David A. Giesselman wrote:Sorry for the confusion, but I didn't write Windows. :wink:
That's true - 'cause if Dave wrote Windoze it would have worked as promised, and then some!!! :twisted:
Rock on, Dave!!! :D
Users browsing this forum: No registered users and 71 guests
