From Windoze:
As always, use extreme care when exploring/editing your registry.
- Start
- Run
- Enter regedit when prompted for what to open/run
- Your registry will be opened in a familiar Explorer style dialog
- Expand HKEY_LOCAL_MACHINE
- Expand Software
- Find the branch named DATACAD LLC and highlight (select) it
- Select Registry (or File) from the menu bar
- Select Export Registry File...
- In the file save dialog under Export range, choose Selected branch
- Name and save the file
NOTE: I would save the file to your DataCAD folder to be backed up along with everything else. Then, when you restore your DataCAD directory, all you need do is double click on the registry file to import it.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
[email protected]
![Image](http://s4.postimage.org/lizbn5es/yingyang.gif)
DATACAD LLC
[email protected]
