#2536 by DBrennfoerder
Sun May 08, 2005 11:36 pm
What is the easiest way to divide an angle into n equal parts. It looks like it should be another geometry function, pick angle, divide into n parts, and identify the two lines to bisect, or n-sect, into parts, then DataCAD would put gray dashed lines at the appropriate locations all intersecting with the intersection of the two identified lines.
#2537 by artmanvt2000
Mon May 09, 2005 7:11 am
If you draw an arc, with the center being the intersection of the two angled lines, and match the angle. Use the divide command to divide the arc into equal sections. This method also works really well for creating 3d arcs by using small slabs. I hope this helps.
#2550 by DBrennfoerder
Mon May 09, 2005 3:59 pm
Wow, that's so intuitive, I'm sorry I hadn't even attempted to try it. Learn something every day, for sure.
#2551 by Nick Pyner
Mon May 09, 2005 9:03 pm
Hmm... Is that the difference between a motorbike and a pushbike? :roll:
#2559 by Miguel Palaoro
Tue May 10, 2005 9:49 am
Nick Pyner wrote:Hmm... Is that the difference between a motorbike and a pushbike? :roll:
That is great Nick!!
With DataCAD you save a lot of fuel!!
But you must be a key athlete. (ho! ho! ho!)
Miguel
Users browsing this forum: No registered users and 62 guests
