#25755 by sledge
Tue Jul 03, 2007 11:45 am
In the Datacad comparison chart I found the following
.DWG AutoCAD R2004 through R2006 drawing file Check Check New!
I Have version 11 at the moment and have had to save to AutoCad 2000 all the time is there an update or something I am missing out on.
Thanks
Steve
#25756 by joshhuggins
Tue Jul 03, 2007 12:25 pm
The "File Compatibility (Open, Import, or Paste)" section says "AutoCAD R2004 through R2006" "AutoCAD R2007 - R2008 drawing file" for ver. 12. Scroll down to the "File Compatibility (SaveAs, Export, or Copy)" section to see Datacad 11&12 only saves up to, uh well it says, R2002 on the comparison sheet, but the dialog box only says R2000, even in my pre-release of v.12? Maybe some clarification is needed here?
#25763 by Mark F. Madura
Tue Jul 03, 2007 3:10 pm
R15 File Format
AutoCAD 2000, 2000i, and 2002
R16 File Format
AutoCAD 2004, 2005, and 2006
R17 File Format
AutoCAD 2007 and 2008
FWIW,
MFM
#25889 by sledge
Sat Jul 07, 2007 10:18 am
Mark F. Madura wrote:R15 File Format
R16 File Format
R17 File Format
FWIW,
MFM
Maybe a little more clarification. What R15 R16 R17 file formats?
Sledge :?
#25891 by MtnArch
Sat Jul 07, 2007 11:12 am
Those are Autodesk's designations for their file formats. If you open up an Acad DWG file in a text editor, one of those designations will show up in the header - it's how lower versions know that they can't open up a file if it's been created by a higher version.
