#29674 by Daniel Kaczor
Fri Oct 26, 2007 2:39 pm
Is there a way to use the scroll wheel to zoom in/out in o2c? and object viewer?
If not, could you please put that on the widhlist?
#29815 by Steve Scott
Tue Oct 30, 2007 7:20 pm
Daniel, I discovered that holding down the right mouse button and moving
the mouse in the "up" direction zooms "out" and moving the mouse in the
"down" direction zooms "in." Give it a try.
#29816 by Daniel Kaczor
Tue Oct 30, 2007 8:14 pm
Yup. and the + and - keys and Ctrl + left mouse.
It's just that I got used to using the scroll wheel in DataCAD that it would be good to use the scroll wheel in the object viewer and o2c.
#29832 by Mark F. Madura
Wed Oct 31, 2007 10:14 am
Daniel Kaczor wrote:Is there a way to use the scroll wheel to zoom in/out in o2c?
I found a utility that might do the trick for you. Mouse Wheel Control allows you to customize the behaviour of the mouse wheel on a per-application basis. You can also assign behaviours to specific windows. It has a small footprint ( 888kb ) and seems to work as advertised.
You can find it at http://www.download.com by doing a search for Mouse Wheel Control. The direct link to the developers web site is http://www.ardamax.com/mwc/.
You can use the following settings that will apply anywhere the o2c control appears.
Figure 1 Mouse Wheel Control Parameters
Now I can use the mouse wheel to zoom in and out within the o2c Player.
FWIW,
MFM
#29857 by Daniel Kaczor
Wed Oct 31, 2007 6:52 pm
Thanks, Mark
It works great. Plus I was able to add scrolling to a other apps that don't support the scroll wheel.
Users browsing this forum: Baidu [Spider] and 5 guests
