1. There needs to be a way to display a sample of each hatch pattern that doesn't permit patterns at tiny little scales to start filling in the window slowly, or else dump you right out of the drawing. A way that doesnt depend on setting display parameters for each pattern. Can't it just be set up to display a certain number of pattern repetitions independent of scale? Let the program show some intelligence!
2. In the batch plot dialog, there shouild be a way to easily add multiple instances of the same file (so you can print multiple multi-page sets COLLATED) instead of having to browse each time back to the same file.
Carl J. Steidel
LAWRENCE S. SCHREIBER, AIA - ARCHITECT
922 East Kennedy Blvd
Lakewood, NJ 08701
732-886-5290
Lakewood, NJ 08701
732-886-5290
