Miguel J. Palaoro • Porto Alegre • Brasil
[DataCAD user since V.4 • Languages: English & Português • Scale Type/Unit: Meter-ABNT]
It would be handy of the export dialogs remembered their last status, like the File, Open, dialogs do.
It would be nice if when we Ctrl+Right Click on a symbol and choose Symbol Tools, (Edit) Replace, we could pick a symbol not yet in the drawing from a file dialog. Either by adding a breadcrumb arrow to the Ctrl+Right click menu for "From Drawing" and "From Folder" or something similar or in the Datacad (Edit) Replace menu.
As a "work-around" to , if we could Identify a symbol and have a "To Drawing" option or something similar to insert the path+name of the symbol would be very handy. Maybe since there are may different fields available when we identify an object we could click To Drawing, then click the field we would like to insert as text.
Until the mythical Smart Arrows make their debut, how about adding two offset items to the current arrows. Head Offset and Tail Offset. We could set values for these that would subtract the distance input from the first and last snap points. Should probably be a ratio to the text size to make them play nice across the board. Whatcha think?
Hi Josh,
I'm not clear what the offsets would be -- maybe you could illustrate it?
Or, maybe we'll get smart arrows soon? Domenic in our office (who recently joined us, and most recently was using AutoCAD) asked about them this very morning!
It would basically allow you to snap directly to objects (mainly text) using arrows without the need to manually erase or trim away parts of the arrow which overlap or are too close to the object you are snapping to. In my example below the tail of the arrow is too close to the letter D. We always have to either just fake in the arrows which is not very clean looking, or snap directly to the objects, and then clean away a space. We do this for 90% of our arrows. If the "gap" could be automatically added by subtracting a ratio from the first and last snap points of the arrows input, would save us a TON of cleanup time. For our office we would probably set just an offset for our tails and leave the heads set to 0 for our standard. But as I was creating the example below, I thought if I had the head offset set I bet the arrows calling out the white snap points would look better if they were offset a bit away from what they are pointing to. I would guess the head offset would be the least used of the two, but still very handy when needed.
Arrow Head & Tails Offset
It would be nice if we had an ini option so that when we have ortho toggled on, when we scroll using the mouse wheel during a operation like setting a Move distance, the zoom point is not at the end point of the ortho drag, but centered on the cross hair center point as it does not zoom as it does when outside ortho enabled commands. It seems less intuitive as it is now.
It would be nice if in the Purge dialog when we select a GTV to be included in the purge, that it would not keep us from deselecting layers. I have a file I wanted to purge to remove a bad layer, but I also wanted to keep all the GTV's, but couldn't just deselect the single bad layer. I think if you select a GTV it should set all of the layers to be included, but If you remove a layer which may be included in a GTV, it should not uncheck the GTV? What do others think about how this should be handled? I just can see coming across this situation above again and hope there could be a way to do it. Is there already?
Could we get one of the following options so we can control the Fast Symbol, Fast 3D, Quick and SelSet options under the More Options in the Object snapping menu in macros please? Fast Symbol seems to catch us off guard the most around here.
Idea 1: Make the Object Snap None option also turn off the More Option snaps. This might make the most sense since they are also snapping options, and when setting your snapping via a macro now this is used to clear the current settings.
Idea 2: Add function codes for each object snap option.
Thanks
Thanks
Users browsing this forum: No registered users and 101 guests
