rogerra wrote:How come when I open a .dwg file in datacad the text comes in as Mtext?The original entities in AutoCAD must have been MText. DataCAD imports them using the same parameters that defined the original entities.
rogerra wrote:Each line of text is a separate Mtext entity and I have to open each one to edit them.You could ask your associate not to use MText, or you could [Ctrl]+[right click] on each one and choose "Explode."
Is there some way to avoid this?
A quick way to convert all MText entities in a drawing is to save the drawing back to DataCAD 11 format. Since DataCAD 11 did not support MText, all MText entities get converted to single line text.
To save a file back to DataCAD 11 format, choose "Save As DataCAD 11 AEC" from the "File" pull-down menu. You'll need to supply a new name for the file as part of this process.
