Recently we recieved civil dwg, which had 3D lines and as well as lines drawn above each other.
How do I delete multiple doubles?
> is there an easy way to remove multiple copies of lines from a plan drawing? (similar to what is available in 3d-hide)
> i've imported a file that has 32 and or 64 copies of many but not all of the lines in the drawing.
Sure -- you can actually use the 3D Hide, layer by layer. Save each "view" out as a layer file. Then erase each layer, and Load them back in. Oh, and make sure that you have Delete Double (on the second "page" of the options menu) toggled *on*.
Users browsing this forum: Majestic-12 [Bot] and 22 guests
