#49843 by Nick Pyner
Fri Aug 20, 2010 8:30 pm
After a bit of tearing of hair over at Greg's last night on the abovementioned picture mount problem, I am concluding that o2c will not work with a single polygon.
Is this an X3 bug, or has it always been the case?
A single slab is OK. Maybe o2c refuses to accept a poly because there is a dimension missing and it isn't a 3D model.(?)
#49849 by Rick Oswalt
Sat Aug 21, 2010 4:16 pm
It seems, if I understand your need, if you draw a vertical polygon any length then add 1 millimeter polygon on the end it will appear in O2C
#49852 by Nick Pyner
Sat Aug 21, 2010 8:11 pm
OK. Two polys.
Thanks
Users browsing this forum: No registered users and 35 guests
