#50554 by joshhuggins
Tue Oct 05, 2010 7:27 pm
If you haven't taken a look at the X3 manual, your in for a treat! It's been getting a great refresh. The PDF has much better hyperlinking, complete bookmarking, updated diagrams, a 2 column index vs. the old 3 column index which allows for longer descriptions which helps finding what your looking for faster, and some other new goodies. Check it out!
#53150 by joshhuggins
Tue May 03, 2011 11:12 am
It's not working in the full version of Adobe Acrobat? Have you tried Adobe Reader? It's working here on PDF XChange Viewer.
#53283 by David Ramey
Fri May 20, 2011 2:29 pm
It's not working on the basic version (Acrobat X 10.0.3) that reads and writes. I have to have this to be able to do multiple plotting on Win & Pro 64 bit with our Xerox 6204 as there is an issue with the driver on that utility called BT Plot assistant. If DataCAD would put multiple pages into one file, I probably wouldn't even need it, but it does work pretty well for that without changinging vector data to bitmap and so on like the free PDF writers out there.
I believe there is a bug in that PDF file because I don't have this problem with other PDF's hyperlinks. I'm thinking DataCAD must have used a non Adobe writer to create the help file. I tried to Edit it and re-save it but it's locked down.
