#3709 by GeneT
Fri Jun 24, 2005 8:33 pm
I was wondering if with DataCad Light, Lists of materiaels can be generated from complete drawings.
Also would this be possible from imported AutoCad drawings.
Any help would be appreciated, thanks.
Gene
#3713 by Miguel Palaoro
Sat Jun 25, 2005 12:20 pm
Hello Gene,
It's good you rise this point, because it allows us to discuss about a way to face this subject, that IMHO is one of our biggest challenges to the future of DataCAD. Every project must have a cost appropriation. All this 'BIM' solutions are commited to address this subject.
My guess is that we can deal with "our" solution, starting by this item: Takeoff.
In older versions of DataCAD we had available a macro that would signalize this direction: Est-link which would allow to set classification for entities in the drawing. The macro 'Est-link' is no more available in DC 11.
To get the results that we are looking for, we should start by a preliminary phase, where would be necessary to discriminate the drawing entities that later will be taked off.
Please, take a look at the first image below, which looks to the wall segment from the 'internal' position. This is a typical wall as it is built in Brazil. Probably you will have countries where the wall are much more complex, what will require additional care.
As you are aware, in the 'real life' a Wall is more then a graphic representation. It includes the different materials which we will need to get the inventory.
In the External view of the same wall can exist a different treatment, as I suggest below.
But when we produce our drawing, primarily all we have is this simple drawing.
So, our challenge is to turn a simple 2D (or 2 1/2D) drawing into a fully attributed model.
Perhaps we should work with 3D elements. In this case, the 3D entity, like the slab (e.g.: the wall) must be classified in its integer form and also, separately, in its faces.
I remember the macro 'Touch-Up' which has a very smart selection feature, which 'blinks' each face of an integer entity, in sequence, until you set the choosen.
WORKING IN 3D IS A NEW FRONTIER
Here comes another problem. How can we deal with the 'documentation' work, since the 3D modelling is not so friendly as the 2D drawing. Perhaps we should join 2D habilities into the 3d modeling. At least in the first steps.
I think this subject is only on the beginning.
Miguel
#5102 by joshhuggins
Thu Aug 11, 2005 7:01 pm
Excellent post again Miguel :!:
#5107 by MtnArch
Thu Aug 11, 2005 10:24 pm
Here, here!! Well said, Miguel!! Maybe you should get a grant like Geoff Langdon and do some tutorials, too!!!
#5124 by Dick Eades
Fri Aug 12, 2005 9:50 am
This is the key issue in my mind in the development of all CAD these days. When we can define how we will use 3D to communicate construction documents, then we will have made a great leap forward. For now we are stuck in having to use conventional 2D communication, either in print form or on screen.
#5126 by Miguel Palaoro
Fri Aug 12, 2005 10:00 am
Thanks Guys, I feel flattered.
The biggest credit, however, is for the intelligence on this forum engine. It allows to insert images and texts without need to make any extra effort for HTML jobs.
Indeed, I am very excited with the possibilities opened by Mark, Dave, and their crew at DATACAD, for the development of next major releases of DataCAD. With the possibilities to talk among us, with this forum as it is prepared, we can exchange clearly a lot of experiences to help us all to be watching the same target with equal lenses.
As you too, for sure, I am just waiting for the commands from Avon's headquarters.
Miguel
#5134 by joshhuggins
Fri Aug 12, 2005 11:41 am
Miguel Palaoro wrote:The biggest credit, however, is for the intelligence on this forum engine. It allows to insert images and texts without need to make any extra effort for HTML jobs.
Hmm..... got me thinking, could we inset O2C objects? Doesn't look like it. Just links to objects.
http://www.hugginsfam.com/dd/ss/Base.o2c
Users browsing this forum: No registered users and 41 guests
