Okay, I use Direction / Distance and this may depend on that, but if I am Move / Dragging something and it is "on the cursor", if I then enter a distance, it moves that distance. That is cool... I maybe should have already known this, but now I do!
damian wrote:If you want to draw a line from a known point, click on that point, then take off with the right mouse button and type the distance. It's like 'reference point' but faster.You can achieve the same results by using [Ctrl] + Left-click which allows you to set a reference point without drawing a line.
You can also use [Ctrl] + [Shift] + Left-click which allows you to object snap and set a reference point without drawing a line.
Users browsing this forum: No registered users and 49 guests
