I am trying to create bitmaps of a 3D model created in Datacad 12 using the wireframe display mode in o2c so we can get just the rough outline to compare existing and new conditions. I have set o2c rendering settings (by color) to render the model black and all looks good in o2c but the bitmap has gray and intermittent lines that barely show up when plotted. Bitmaps are 8 mb in size and saved using high res setting. Don't know what else to try. Thank you.
Dan
Dan
Dan Martens
NBF Architects
Rutland, Vermont
NBF Architects
Rutland, Vermont
